Gravely ZT48XL with Kawasaki 24hp hard starting
JR645
This mower is 12 years old. After ?? 6 or 7 years it became hard to start. Click, Click, click and then it would catch and start. Cold or warm engine made no difference. I cleaned all of the connections and grounds no change. Three or four years ago I took it in and spent $1200 on it for that and several other things and it was better when I got it back but still did it. Now it is back as bad as it ever was. I do NOT want a new mower I want this one to crank like it did when new.. Perfectly good mower otherwise. Any suggestions?
mechanic mark
JR645
model 915156, ser 001240
This may be the mower if so I will go look on the engine in the morning.
mechanic mark
Wiring schematic show a remote starter solenoid. I would start with replacing it as they do burn the internal contacts will lead to operative solenoid contacts. Next would be the starter itself.
