Flick
no power to the clutch. fuse is good could it be a relay?Basically the same circuit except it has more fuses.
Gravely 991166 (025000 - 034999) ZT HD 60 Wiring Schematic
ok I found a blown 10amp fuse inside that GEP box getting power to the relay plug now.That is why you have the wiring schematic so you can trace the circuit.
Yes the relay contacts could burned but you got to test the circuit path to find where the voltage is dropping out. Might even be the fuse holder contacts. Just won't know for sure; unless, you test. It is the same thing I would do here in my shop.
TY StarTech I got it going, after I found the fuse inside that GEP I forgot to plug the relay back in. I just taped up the two ends for that PTO diode so they would not ground out and pop the fuse again. I got my grass cut. TY again for all your help.That is why you have the wiring schematic so you can trace the circuit.
