Captainbigwood
- May 24, 2013
- 1
- 3
I am having a problem setting up the steering to go straight with both levers full forward. Yes I have tried the adjustment stops for the levers. The right lever has more power than the left. I have serviced the hydraulic fluid and filter, replaced with Gravely dealer items. I understand the deck lift valve uses some of the fluid from the pump that may be an issue. Any experts out there?
