Hydrochronic
- Jul 12, 2012
- 1
- 2
Gravely Z144 blowing 30amp fuse when engaging blade....am I getting an arc somewhere? Troubleshoot advice? Easy answer?
Should a good Coil have low resistance ? I would expect a Good Coil to measure a short or very low resistance. I'm having same problem on
an Ariens 1028 Rear Rider. But my PTO Belt isn't turning when Blade isn't engaged. My Idler Pulley Spring is off. I can't figure out where it connects.
