chevydropped
- Apr 20, 2015
- 1
- 1
I recently purchased a Gravely 160 commercial with a Kawasaki engine. I had to replaced the key switch when I bought it. The mower one day stopped starting. I jumped key, PTO, brake, seat switches. I also swapped relays around. Still nothing. Then I noticed that the starter solenoid was jumped with an extra relay to make work. I removed all extra wiring and jump solenoid on starter nothing, would not engage starter. I purchase new starter and installed and mower started right up. I used for a weekend and was getting to last yard drove out of the trailer and turned off to close door then started back(reason for turning off is since starter replacement, unit kills when I get off the seat, possible brake switch). Got on unit tried to start, it started for a second then killed and no clicking noise at all, Thoughts?
