Gravely proturn152
hpratt
Bolt and washer came out of end of shaft of the Kawaski fx691v and was lost. I live in the sticks and no dealer within 100 miles. I need to know the size of the bolt that goes in the shaft end. Clutch fell off but I found the key and spacer. I'm sure the bolt must be metric. I may be able to find one in hardware store. I'm old school and no nothing about metric.
Thanks. Good idea. Description said .44 20x2.50 G5YZEP80. I googled that but could find nothing to match that to a bolt. But did get a part number.
I don't think the bolt and washer were ever in there. After I replaced it the mower ran better than new. Less vibration and noise. The key way was a little messed up because the key was half way out. I can't believe how smooth it is running. I check it before every use now.
