Engine Gravely Model 915076
Mower info ...... Model # and serial #
Engine info Kohler #'s on engine all the numbers....... Spec ETC ETC.........
How many pins on your plug harness also......
mjharrell
Gravely ZT1840
Model 915076
Serial 020214
engine PS-SV540-0022
Engine Serial 3530915573
will get pin number tomorrow
mjharrell
the connector for the engine is a six pin connector with only 4 being used.
Ok .......... Got some info for you..... 33S877-0019-G1 is the engine that will fit on your mower....... Everything bolts up and plugs in.........
Plus Tard Mon Ami ~!~!
mjharrell
got the block welded up and in good shape and finally got it back together, now i have a problem with fuel spitting out the filter side with the filter housing and filter out and no power, figured that is flooding even tried a new carb with same result kinda stumped.
mjharrell
found intake valve was not seating properly, lapped intake and exhaust valve back in and brought life to the engine even cut grass.
