Gravely HD bagger size
Dataz722
I am wondering if anyone here know how much width is added to the deck of the Gravely HD when you add the bagger with the blower? And also how quick and easy is it to remove the blower if need be to get it through a fence gate?
Thanks.
Jake in CT
About 12" in width. Pretty easy to take off, maybe 2-3 minutes.
I use a screwdriver to wedge the blower pulley back, then pull the belt off. Then you just have to lift the blower off.
