wizzzerski
- May 22, 2017
- 2
I have a Gravely 2042 ZT - Model No. 915134, That has a serial number is the first set of numbers when looking up parts.
The problem I have is the Clutch Stop Broke, which allowed the Clutch/PTO to spin more than it should have and broke some wires in the harness going to the PTO. I replaced the Clutch Stop, and with some crimp style connectors I was able to fix the wiring. However, after cutting a few times, my sub-par repair of the wire harness has now failed, and I need to replace the harness.
The issue I have, is the harness on this mower, is all one unit, and to fix this problem, I have to replace all wiring on the mower. Seems like a lot of work, and expense due to one connector going bad.
When I look on Gravely's part site, the harness I need is Part #02974500 and Diode (#09293500) which is included with the Harness.
My question for all of you: Is anyone aware of somewhere I can buy the end of this harness, and not have to buy the full harness. Maybe a used part off a mower that is being parted out?
I assume that I need the last 9" - 12" of the harness, and I'd be able to splice the two harnesses together.
Any ideas you have is appreciated.
Thanks
Thanks
