do I really have to take the engine out to replace the coil????
L lazyacre Forum Newbie Joined Apr 26, 2016 Threads 1 Messages 1 Apr 26, 2016 / grasshopper720k coil replacement #1 do I really have to take the engine out to replace the coil????
BlazNT Lawn Pro Joined Apr 26, 2012 Threads 28 Messages 6,973 Apr 26, 2016 / grasshopper720k coil replacement #2 Too many engine options to know. What engine do you have? Model number of engine and mower?
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Apr 26, 2016 / grasshopper720k coil replacement #3 To replace the coils you need to remove the engine cowel so it all depends upon what engine you have in there and how it is mounted. If you have a flywheel type PTO then it will require a reasonable amount of dissasembly.
