tom3
- Apr 9, 2018
- 25
- 1,579
I'd guess with the cylinder not firing and the actual much lower cylinder pressures and temperatures the engine would not be damaged at this point. Pressure and splash lubrication should have kept wear to a minimum, maybe even less than the other two cylinders that were doing all the work. Really good that you discovered this too!
