grasshopper 720k wont go forward
720k
Hello all, my grasshopper 720k drove fine all the way down my .5 mile long drive way to my front field. I stopped and shut it off to cut out some trees before I started mowing. Upon restarting the left wheel would not go forward, right works perfect. Left wheel will go in reverse fine as I had to back down entire driveway to get back home. All the linkage looks good, and fluid is good. Any suggestions?
For the life of me can’t think of what the set screws are called, but they are located under hydraulic filter plate. The forward one backed completely out and the others were dang near close. Called grasshopper and they were phenomenal, gave me two things to try first and emailed me diagrams and what to check. Was told if that doesn’t fix it call back and they would help me dig deeper
