logsdonj
Over the weekend, I had a noise come up that can be heard in this video I made.
The mower has around 50 hours on it.
The video starts at 1/2 throttle with the high pitch noise, I increase to full throttle, then bring it back down to idle by 15 seconds before disengaging the PTO at 27 seconds.
I increased and decreased belt tension an inch this way and that with no audible effect to noise. I know the manual says to only have 5.75" for the spring expansion, but it had about 6.5" when I took the cover off... again, only 50 hours on the mower, so that's how it came and I'm not sure how else to check what tension should be. I slacked the spring to 5.75" now but it's near the end of spring bolt and I don't know if that's enough.
I check the larger idler pulleys in this video:
There doesn't seem to be any large play in them. The one on video right/driver left had a little bit of a whir to it when spinning freely, but I had to put my ear close to it and it still spins well. The bolt holding it on was loose when I first checked everything... I only noticed when trying to tighten bolts.
The spindles and blades seemed tight without play. When spinning the middle blade, some small noise can be heard inside the spindle housing at different rotations, but the same with driver right one also, but I did not have time to take off blades and spindle housing to inspect. It could have even been some debris rubbing against the spindle housing during rotation that I didn't see.
Before digging more, I'm hoping it will sound more obvious to someone with more experience. The mower is at family's place that's a 3 hour round trip, so I'm not able to check more quickly. Thanks!
