C curt0305 Forum Newbie Oct 6, 2018 #1 I have a grasshopper 616 that started using a lot of oil and smoking this summer will the engine decided to die looking for a replacement engine that will fit into the 616 with out a lot of retro fitting any ideas thanks Curt0305
BlazNT Lawn Pro Oct 6, 2018 #2 curt0305 we need to know the full model number of the engine you already have.
C curt0305 Forum Newbie Oct 6, 2018 #3 BlazNT said: curt0305 we need to know the full model number of the engine you already have. Click to expand... it is a Vanguard 16 v-twine engine family ABSXS.4792HH 279306 eu e11*97/68SA*2004/26*0331*01 just pulled a valve cover and a broken push rod hope this helps thanks
BlazNT Lawn Pro Oct 7, 2018 #4 No those are the EPA numbers and do not help. The model number is imprinted into metal somewhere around the exhaust.
C curt0305 Forum Newbie Oct 7, 2018 #5 BlazNT said: No those are the EPA numbers and do not help. The model number is imprinted into metal somewhere around the exhaust. Click to expand... model is 305447 type 0217-G1 code 0032211 also sending picture
BlazNT Lawn Pro Oct 8, 2018 #6 Try this one. https://www.amazon.com/Briggs-Stratton-305447-3077-G1-Vanguard-Crankshaft/dp/B007Q8JTG0
S SidecarFlip Well-Known Member Oct 8, 2018 #7 BlazNT said: Try this one. https://www.amazon.com/Briggs-Stratton-305447-3077-G1-Vanguard-Crankshaft/dp/B007Q8JTG0 Click to expand... Wowzer, the Harbor Freight Predator is half that price, every day.
