Grasshopper 1990 1212 wiring
Kslivin
Started a rewire project on my 1212. The guy before me put a 12hp Kohler engine on it with different wiring from the original engine. I’ve tried to wire it up best I can figure from what the manual says but when I turn the key nothing happens.
The wiring harness has a green wire, where does this hook up at? It comes from the switch to a eyelet connector than branches off to a female spade than back to a eyelet. My manual doesn’t even show it. Also the red and yellow wires going to the engine. I hooked the red from one side of my coil to the (+) side of the relay solenoid. The yellow from what the manual says should go to the alternator but this engine doesn’t have one? Any help would be greatly appreciated!!
