Mulching Grass pushed down
Kevinp
Does anyone have the problem of your mower pushing the grass down after you mow.
I also get a lot of stragglers (grass sticking up after I mow.)
I use a mulching deck?
Clean underside of deck, & remove, clean, inspect & dress blades with a file and check blade balance before reinstalling. If blades are cracked, bent, distorted or otherwise replace them.
