Is there a way to fix the problem of grass left uncut between the blades? It is particularly bad between the left and center blade. I removed the relatively new blades (installed about 2 months ago), and rotated them, L to C, C to R, R to L, and I get the same result...2 stripes of grass the entire length of my mowing, which means I have to mow over the same path a second time, but slightly moved to the side to make sure my blades cut the 2 stripes that are left between the 3 blades. The grass between the left and center blade is up to 12" wide, while the grass left between the center and right blades is about 2-4" wide. I have the ProMaster 260.
