Engine grass hopper 721 gas won't crank
fickit man
I have a 721 grasshopper and it will not crank when trying to start it. Have all ready verified voltage and replaced the start switch. I have no voltage to the blue wire on the start switch or across the center fuse. When I turn the key on I get a hum sound in the back either from the starter or clutch. ....
are your steering levers pushed all the way out?also safety switchs for each lever.one or both could be bad...russ
