I have a Husky with a 21HP B&S. Some time back I fitted a dual temperature display to monitor the Transaxle temp (usually 65DegC) and the engine (oil filter) temp (usually 70DegC) and I have kept an eye on them both over the last few years. Tranny Temp is still the same but more recently I have noticed that when I finish mowing (the usual lawns) the engine temp is 99 to 105DegC.(221DegF).
Is that too hot? and any ideas what could be causing this heat creep?
Many thanks.
Neo
Many thanks.
Neo
