I have a GR2100 and have had problems with the rear transmission. I noticed the left rear wheel had a funny noise to it and when I made a left hand turn, it dug up the grass. I checked the transmission oil level and there was none showing on the dipstick. Went to Kubota dealer and asked them where I would put oil in. The salesman didn't know, went to the service department and found out that you have to take the dip stick out and pull the rubber lining out, buy a funnel and fill it that way.
The salesman said it needed 3.4 qts of UDT, so I bought a gallon. I went to put some in and thought I would just put in one quart, which I did. Then I found out it was FULL. I had to way to get oil back out unless I took the bottom suction pipe off and drained all of it. So, I went to Tractor Supply and bought a Siphon. It sounded simple to do. However, it did not pull much oil out and the dip stick still shows it is way too full, well over the maximum mark on the dip stick. I don't know if the problem is because oil will not flow through the siphon like gas or water will. So, I got oil all over everything and still have a problem. If I can't figure a way to get more oil out, I will have to just drain it.
I never thought that with a dip stick showing NO oil on it all, could be filled up with about a half quart.
I am open to any ideas.
Bob Oren
Bob Oren
i just picked up my kubota today had to put a new tranny in it they have nothing but problems with this particular tranny kubota supplied the tranny and it cost me 1500 dollars to change it good luck
Purchasing my GR2100 is the biggest mistake I ever made. The transmission/rear axle was factory recalled and had to be replaced. It took two trips to get it right. Soon after that the factory issued another recall for the cables that control the 4 wheel drive. That has been installed but is again about to fail. The machine has less than 200 hours on it. There is a dealer in Tulsa that advertises "If it ain't orange, it's a lemon". Well my orange Kubota is the only lemon I have ever owned, and it truly was poorly engineered. The cable kit will solve your wheel engagement problems, but it is expensive unless you can get Kubota to pay for it.
Holy thread resurrection Batman!
So there was a recall on these things?
Never heard a word from Kubota or my dealer.
