Governor Seal for GCV170? SOLVED
Trig
Does the governor seal (91231-891-003) for the GCV160 work on the GCV170 the engine for the HRN series?
Scrubcadet10
Moderator
Staff member
continued.. Don't see it fitting a 170 anywhere
Trig
Was thinking maybe list not updated yet. I will find out since I got one for $4.60. Crank housing and gov shaft look the same but...?
Scrubcadet10
Moderator
Staff member
Worst thing that can happen is it not fit, if it fits, you may save some people a headache. (y)
Trig
My thoughts also Scrubcadet10... We'll find out...
Yes it is the same seal considering the GCV170 and GCV170H uses the same crankcase. Oil seal shows on the GCV170H series, types N2EE,N2KE. I don't see why it will not work on all the same crankcase.
Trig
I will report in about a week or two...
Trig
The governor shaft seal is not scheduled to arrive until Sept 25.
Trig
I have installed the governor seal Honda# 91231-891-003 on my new HRN216 mover. It has the GCV 170 engine.
It fits, is the correct part.
It took me about 20 minutes total, I took my time. It's disappointing that Honda opted not to include it on the engine.
There was oil residue already (before the seal), after less than an hour of use.
The online videos were a big help, especially the one from Taryl Fixes All.
Thanks also to Scrubcadet10.
Trig
