governor problems and more
ACF
have briggs 44n877-0005-g1 came in running at max rpm, found that governor was broken, after pulling engine and opening engine found that there was cracks on both cylinders going into cylinder. have attached photos not best, was wanting to know if i should continue with replacing governor putting engine back to operational status
thanks
To my knowledge those are casting lines made when the block was cast. I personally have seen them many times and wouldn’t worry about them. Remember read my signature.
Man those look awfully similar. Other than the one and the two. Sure look like cracks to me. Strange way to put casting numbers on. ????
These castings are made by a casting procedure known a "lost Styrofoam" casting and it often makes some strange impressions in the aluminum metal surface that can be perceived a faint crack, but they are not a crack. They are literally a pressure seam. Back in the cast iron days they actually had raised flashing seams that machinist had to clean by hand.
You can verify this with a back light if I'm not mistaken but they do not look like anything to worry with, I would be more concerned with the governor
