Little John
- Aug 16, 2012
- 6
- 20
Hi all,
I recently replaced the base gasket on my CC 18M push mower, and in doing so, I removed the governor arm on the engine without realizing what a PITA it would be to re-animate the thing. There's a pivot pin going into the engine that the arm mounts to, but the stops on the pivot seem to be determined based on how far in or out of the block the pivot sits. I can't find anything about the proper setting on the pivot, so any and all advise would be hugely appreciated. Thanks! -LJ
