Mrbill1
- Mar 4, 2019
- 9
- 22
I'm having an issue of over revving on my Briggs and Stratton 20 HP Intek engine Model # 47777 0121 E1. I've tried resetting my governor adjustment with no change. I find no binding in my linkage. I have tried disconnecting my throttle cable and both springs allowing only the governor to control the throttle with no change. It appears to me the governor is not working. Is my assumption correct? If my thinking is correct the throttle is wide open at time of starting and after the engine starts the governor then controls the speed. Allowing the governor alone to control the throttle should keep the engine at minimum speed after cranking, shouldn't it? Any help would be much appreciated.
