govenor spring briggs stratton 24 hp engine
bootts
model # 446777-0302e1.govenor spring--big spring--one end of big spring hooks to bottom of gov. lever,where does the other end hook to? thanks
motoman
I have an Intek 24 . I will try to look for you.
Goes to the throttle control lever, which you move when you push the control on the dash.
motoman
If I'm reading your question correctly...First, a large bracket is horizontal, bolted to both heads. On that bracket are two stationary eyelets. Little spring eyelet is below (you apparently know it because it is attached, right?)
Then the big spring eyelet is above. With the hood off mine , but without the muff heat shield removed I can just make these eyelets out. The Intek manual shows them , but not helpful from the drawings. My Intek engine 274844 24 HP 2003 vintage.
