neighborbill
- Jun 17, 2012
- 9
- 71
I have a Trail Blazer Sickle Bar Mower with a Briggs 4 hp engine. I"ve had it for years but really never used it very much. I decided to bring it to life recently.
I found that the gas tank with carb attached was the main problem for starting and running. So I bought a used carb and tank with a bulb primer .
I have the engine running now, but the governor with springs is the problem that I have now for control of the speed.
My govenor control arm is on the opposite side of where all the other pictures show it to be. So the usual two spring attachment isn't going to work at all.
I have a single arm that attaches to control arm buried inside the covers. It looks like it was just pushed into a plastic fork like holder. It won't reach the carb throttle set up because it is two short.
This engine is a verticle drive for the sickle and it has another shaft (geared) for the wheel drive. I've never seen this kind of a set up before.
The simplest thing that I can think of doing (and it won't be simple) is to make another connecting arm that is longer to reach the throttle bracket and then connect some spring set up for control.
I've just about given up on this project but thought I would write for any comments on it.
I've written Briggs about a new engine but I'm pretty sure I won't get the ansewer that I need.
This is a beautiful machine and practically new. I'd have to give up on it.
