Got fire...won't crank
obsessionlawns
26 hp Kohler EFI had the wiring harness pinched by body. I repaired all the wires. Now when I crank it won't fire off. Thinking I have an electrical problem to the injectors. Any ideas?
Fish
Wow!
So when you turn the key, what happens? It cranks? Let us work out the meanings first.
briggs
if it rolls over and u have spark its a fuel prob check to make sure there is power going to the fuel sel
