I replaced the vr : getting 40 ac from the two white wires. Only getting 6 volts from the middle blue wire. At the battery I read 13 volts. I ran mower for an hour and half and cut it off and it woudn't start. It squeals turning on Pto, so I assume blelts are worn. Can the tensioner be all the way out? Next problem, this was the first time, levers forward and it barely moved. I went forward and backward and it finally moved, but it took a ways to get up to speed, It takes off slower than it used to. Usually you can spin the wheels if you hammer the levers forward, but not so much now. Has HF. Suggestions
Thx
Thx
