GH 614 traction kit
jlasater
The rear weights on my 614 are missing. The previous owner doesn't have them. It's easy to bring the rear end up if I'm not careful on the sticks. Does the traction kit amplify that effect at all?
Another question...if I mow mostly flat ground, is there any reason to have the traction kit hooked up? I thought about just unpinning it from the deck but leaving it otherwise installed.
I'm going to have a couple 30lb weights cut from 1" steel plate and installing them on the back end.
