I would recommend the new Honda 3000 watt inverter genset modeled after the 2000I at around 75 lbs it is portable, with recoil start, very quiet and will have no problem running a gas or oil furnace, tv, fridge freezer or other small appliances.. I have several gensets gas and diesel, the small Honda's are the ones that get used the most. I have the 2000I which weighs about 46 lbs and runs almost all day on 1 gal of fuel. If you compare these small Hondas' with the open frame budget gensets you will be amazed at how quiet these things are.
If you must have electric start the 3000 w Honda with built in tank and battery is super quiet at 58db but weighs about 140 lbs. While a good unit I find it to be too heavy to be considered truely portable. While I like the one I have it is mounted on the rear of our 5th wheel now and bought the 2000 w model to serve as the "portable".
My choice of small diesel gensets are the Onan "Commercial Mobile Quiet Diesels" CMQD models I have a 5500w on one of my service trucks. These are equipped with a Kubota diesel engine and water cooled with choices of 120v, 208v 3phase or 240v, 50 0r 60 cycle models too.
