zman111666
- Mar 4, 2017
- 147
Hey, folks!
I'm working on a BlackMax 7000 Generator with a GX 390 Honda that was recently converted to propane.
It runs fine on LPG, but when switched to run on gasoline, it surges and backfires a little when under load. The load is approximately 4500 watts, so well within the capacity of the power plant.
Has anyone else run into a similar issue? I was a bit concerned that maybe the problem is that the donut that supplies the LPG is restricting the air when it is running on gas, as it is a perfectly round opening, and the carburetor has different shapes in the opening to allow for ports to get air.
Blackmax BM907015
Honda GX 390
Blackmax BM907015
Honda GX 390
