GCV160 Question
Does the Honda GCV160 engine have a real carb, adjustable, and with a bowl?
Yes, the carb on the GCV160 is a traditional venturi-style carburetor. It has a float/needle valve, bowl, jets, etc. The air/fuel mixture screw has anti-tamper features, per EPA regulations, but can be disabled for adjustment to factory specifications. Some versions have a manual choke, others use an automatic design that moves with a spring and expanding wax cylinder...
Same is true of the larger, GCV190 engine too..
