gcv160 early piston useable in later block?
pwabnig
Can you put an early fat ring piston in a later block originally fitted with the thin ring piston? Many thanx,Paul
reynoldston
If the piston is the same size I can't see what difference it would make as to how the ring design would make a difference.
