Gcv 160 only run on choke
jlwoods99
Ok ,it set for a few years, on my pressure washer. 8 believe I put stabill in it. Drained the fuel, started with fresh gas after several pulls but only running while choked, I assume carb needs cleaned, any idea specifically what I need to focus on when I clean it?
Thank you
Jim
