Gas Tank
robert1950us
How do you remove the plastic gas tank on a 2018 Troy-Bilt super Bronco 50 xp riding lawn mower.
Please post the units model and serial numbers off the tag under the seat.
robert1950us
The Model # is 13AQA1BQ011 and the serial # is 1C058H20396 it is a Troy-Bilt Super Bronco 50XP Thanks.
Sorry I’m not going to be a lot of help to you, as I’ve not sure how that tank is mounted. Many times you may need to loosen or remove the dash, which means pulling the steering shaft. If I was standing next to you, would probably figure it out in 5 minutes.
robert1950us
Thanks for the advice, it gives me a place to start.
