Gas tank bracket attaching from older Briggs to new one.
allan01
Trying to add a gas tank from my older Briggs motor (Model 217802) onto a new Briggs E1150 engine that came without a fuel tank attached. Any help with how to mount the bracket that attaches to the tank from the old motor to the new one would be appreciated.
It would help if we had the full model type code from both engine so we can compare them.
The old Briggs is Model 217802 Type 0145 B1 code 0802147A and the new Briggs is Model 21R8070072G1 11.5 hp Type E1150.
Well this is a problem Briggs IPL doesnt show a mounting bracket just a screw and a spacer.
Thank you all for responding. I was able to figure this one out and made the transfer. Good group, I'm sure I'll need yr help in the future.
