Gas oil mixture for Lawnboy
Phototone
The bottom line is, if you run what the manufacturer recommends, you won't throw a rod, or seize-up the engine. Look thru your exhaust port, you got 3-rings on your piston run 16-1 ratio, you got 2-rings on your piston run 32-1 ratio, any brand of 2-cycle oil you please, I prefer LawnBoy brand, and I add a dollop of Marvel Mystery Oil to my 2-gallon mix also. I'm speaking exclusively of LawnBoy 2-cycle engines here.
