- May 6, 2010
- 51
- 11,399
Walt I agree you will not get gas into the crankcase with the engine running without poor running conditions. Could be possible that only one cylinder is firing and pushing gas past the rings or head gasket, or fuel pump leaking into crankcase while running or at rest. but leaking float valve would only fill crankcase while not running.
