Having a little problem with a 21 hp briggs and stratton ohv craftsman mower model 33m777. It had a blown head gasket and was spitting oil out of exhaust with alot of fuel in the oil. I replaced the gasket and it ran fine for about 10mins then the oil filled with gas again. I replaced the carb thinking it was the float and needle. Same thing ran for about 10mins before filling with gas in the crankcase. Took the head off and and reseated the valves and and adjusted them. It ran fine for about 20mins out mowing then came back into the shop to check for leaks and the breather tube had come off and was blowing oil out of the tube and the oil was filling with gas again. Going to replace the breather and filter, but cannot for the life of me think that will possibly fix it. I am stumped and just down to rings, but the mower starts and runs fine when the oil is drain and refilled to correct levels, no smoking or rough running until gas fills into the crankcase. If anyone has any clues would be appreciated.
