gas going in crank case
rawdon
Hi i have Tecumseh motor in my cub cadet tractor 15.5 and gas is going into my oil (crankcase)I put in a brand new carb after rebuilding the old one several times and its still flooding would it have anything to do with the rings
reynoldston
The only connections I can think of crankcase to fuel is the carburetor or fuel pump. Before you get too involved with rings try a gas shut off valve and see if that helps?
rawdon
The carb has a cylioide switch and I also have a shut off valve
reynoldston
The only other connection is the fuel pump or a bad neighbor???
