I purchased a Garden Way Mini Tiller at an Estate Sale. It had not run in years. The Tag on the Engine shroud says 8079 so I assume one of those numbers is the year? I should have never fixed it because it needed a Carburetor, Coil and Axle bearings for the Transmission. I rebuilt the Carb with OEM parts but the Coil was expensive and difficult to locate. Total cost, not including my time, was $92. I like to fix and keep or sell equipment as a hobby. Anyway, I got it running well. The Tecumseh sticker on the Engine says mix fuel at 24:1. I use Red Armour 2-cycle oil in my equipment at 40:1 to 45:1. Never had an Engine wear out yet. Can I run this old Tecumseh Engine using the same mix ratio without issue? I am guessing back when this Tecumseh Engine was manufactured, they didn't have the good quality oils that we have today?
I remember when I was in High School, there was a Garden Way info Commercial on TV. The pretty Girl using the Tiller. When I saw this Garden Way at the Estate Sale, I thought of that Commercial back in the day.
Thanks.
Thanks.
