Jakobbbbbb
- Mar 3, 2021
- 6
I’m going to put a refresh kit on it and if that dosent solve it then I will check the flywheel keyGenerally it sounds like it wants to start. So close. It just won't. It has full compression, so if you're pulling on a rope it feels the same. Your electric starter probably sounds normal. You'll have spark. A little gas in the carb won't get it going. By rights, doing the obvious checks, it should start. But it won't.
