Gas coming out of exhaust
aircore
On a John Deere rider with a Kohler engine it starts but gas starts coming out of exhaust bolwing white smoke then dies.
Mikel1
The carb's float needle and seat are not properly sealing causing more gas to enter. You need to clean or rebuild carb, also check your oil for gas.
aircore
No there is no gas in oil, oil is clean.
John1984
I am a john Deere Mechanic and your carburetor bowl needs to be taken off and your seat taken out and inspected and put back in if in good shape if not then replace it. Another problem could be the electronic fuel solenoid is sticking if it's equipped with one.
Fish
How could the "electronic fuel solenoid" cause this????
