Fv460v
Flyer1275
No spark suddenly I replaced the ignitor the coil and the plug i disconnected the ignitor and there is a spark but random at best bright and blue but will not run on it Then i reconnected the ignitor and then completely separated the mowers harness from the syatem(john deere 160) again no spark so i ran a new wire from coil to ignitor to make sure i didnt have a break or a short Simplest ignition in the world and i cant figure out why i have no spark
Any ideas?
Flyer1275
No it was bad replaced it Didnt make any difference Looking at the wiring diagram i dont see how that would affect the ignition
I am assuming you mean FB460V-???? engine. Kawasaski engines doesn't have a FV series listed.
It wouldn't. Did replace ignitor with OEM or was one those universal ignitors? Right now it sounds like the new ignitor is bad. If the engine has low oil sensor make sure it is disconnected as it could have failed.
