Mr. Mad, just downloaded and printed the owners operator manual. My machine falls into the 4320026 category.
The parts section only refers to the clutch as a clutch with out a manufacturer name.
The clutch does indicate with a sticker " Warner Electric Mag Stop".
the Voltage Out put checked at the battery at full throttle - 13.8
I still need to check the other things mentioned.
Battery Ground connect- need to inspect
Also the amp meter does not indicate it is doing or showing anything. Could that mean something?
thanks, randy
thanks, randy
