Fuse location
thelakeguy
I have a Craftsman zero turn mower model 247.25061 and while changing the battery my wrench hit both battery terminals causing a spark. The mower will not turn over and I think I blew a fuse. I do not know where the fuse is. Can you help in locating the fuse so I can replace it?
Normally the fuse is located in the neighborhood of the battery or starter solenoid.
