shirl67
I live in the UK and have a wheelhorse ride on mower ( Kohler engine ) Fuel is leaking from the tank. Can anyone tell me the part I need. I believe it is a grommet of some sort?
shirl
shirl
At the moment it is in a work shop...The only info I know is its a C-175 with a Kohler twin cylinder engine.Please post the model and serial numbers, located under the seat, as the fuel tank is part of the tractor breakdown.
thank you....Its the nearest thing to a tractor I'll drive..Going to use it to pull a small scoop for horse poo....Our little mini Irish CobsSweet tractor you got there.
Appears to be correct part.Is this the part?
Fuel Tank Bushing for Plastic Fuel Tanks
Rubber Fuel Tank Mount Bushing for Vintage Garden Tractors with Plastic Fuel Tanksisavetractors.com
