dfbroxy
- Aug 31, 2017
- 259
Hi
Kinda new to this forum and know just enough about mowers to be dangerous. I have a John Deere 155c model 445777 0264 e1. Problem is the rubber tube that goes from fuel pump to valve cover dry rotted in half. Is this just regular fuel line or a ordered part? I tried to look it up and it doesnt show on diagram. This is a restoration project with a lot to repair so this might be the first of many questions. The motor runs but has a blown head gasket that Im working on now. From there its on to the jacked up wiring harness. Last owner had a no start problem and tried to bypass all the safety switches with no luck and left me with a bunch of spagitti. So anyway thanks for all input you have.
