TheRiflesSpiral
- May 17, 2018
- 4
- 19
I'm helping my father-in-law with a Hustler Super Mini Z (927277) with a 25HP Kawasaki carbureted motor. (FH721V-CS16-R)
From cold, the mower runs perfectly until it warms up. As soon as it warms up (about 10 minutes of full-throttle mowing with a bagger, not full speed) the fuel filter runs dry.
I assumed the pump was bad and there were some cracked lines so I replaced everything from the tanks to the carb. (Fuel lines, filter, pump, pulse line... not the 2-way valve) No improvement at all.
I considered the pick up tubes might be clogged but it behaves the same way with either tank, and letting the mower sit for 20 minutes or so, the filter re-fills from gravity alone.
The only thing I can come up with is the pulse line losing pulses.
I'm completely at a loss. The fuel system (cold motor, running on the fuel in the bowl) will fill a 1-gallon gas tank in about a minute. Once the motor warms up, there's no flow (outside gravity) to be found.
