Fuel mixes
colmtoland
Hi everyone I am totally new to the forum and have a question about fuel mixes. I have 3 tools HUsq 150 leaf blower(50-1), old Toro Snow Blower (40-1and) a poulan weed whacker (32-1) which all have 2 stroke engines that use different mixes of fuel and oil. The poulan weed whacker doesnt run so good on the 50-1 mix which I use for the snow and leaf blower( they both run fine). Is there any way to make them all run on the same mix or am I dreaming. Any and all info is appreciated and look forward to hearing from someone
Thanks
Colm
Justlawns
Just run the 32:1 in everything the most damage you might cause is a fouled spark plug. Remember spark plugs and oil us cheaper than new equipment
midnite rider
Use OPTI 2 which a single mix works on all 2 cycle engines. One gas can will fuel and lubricate them all.
